Rotex HPSU + RRLQ008 outdoor unit issue
Bear30
Zeit: 25.12.2023 16:42:57
3641265
Hello
Lookin for advice and/or info where i can find the correct manual or info.
Indoor unit: Rotex HPSU 308 with electrical backup heater
Outdoor unit: RRLQ008CAV3
Devices are second hand purchase. Seller told that it has worked with out problem.
Electrical and hydraulic installation are made by professionals and checked many times. Indoor unit works right, we quess. Water/heating lines warm-up by backup heater.
HPSU unit trying start outdoor unit. Pump-logo flash in multifunction display. Some times pump-logo stays few second without flashing. Outdoor unit fan start rotate.
After few second pump-logo disappears in display and outdoor unit fan stop.
No error messages.
On Circuit board PCB3 (service monitoring board) in outdoor unit green led flashing. 2 of 4 red led lights are ON.
Can't find anywhere what those led light monitoring. Do they tell something for issues?
Also PCB3 board has several dip-switch and push-bottoms. Looking for info what they are and which positions are correct?
Any ideas how to solve where is the problem and why outdoor unit won't stay running?
Also interesting find out what does PCB3 service leds indicate.
Brychu79
Zeit: 05.09.2024 13:35:53
3740309
Hi, did you solve your issue?
I have similar from Monday.
Thx a lot for your help.
RayKrebs schrieb: Und welche Spreizung zeigt die WP an? Zeigt die auch ca. 800l/h...
Alien45 schrieb: Grundsätzlich kannst du auch Heizzeiten für die Nacht einstellen....
